How to create backup based on date?
Hi experts,
I am making a backup of my Databasing project.Â
And I just want to know the method of doing some back up for reference and future use?
Thanks
Hi experts,
Thanks
You want to create back-up based on date. I Think something like D/Folder/back-up <date>, you want.Â
If so, I think I can help. Get the Vice Versa help file from:
http://www.compareandmerge.com/
Look for Folder variables there. Set a command for <date> to current date.Â
You’ll get the result.
You can also get manual results from this site:
http://www.joescat.com/backup/
Hope these will help you.
Hi Timothy,
Having your back up with date is a good way of organizing it, while using 3rd party software can help you do that you also can do it by creating a windows batch file or setting your Software to back up having the date as file name.
1. Option create batch file with this code:Â mkdir back_up%date% then you can read through this tutorial to extract characters on how you would want the date to look like, say 05012013.
2. Option: Look for Folder variables or Folder options on your database software then select < date > and this will expand automatically to the current date.
However you have to do the 2nd option when you do back up.
