How to create backup mdb schedule?
Hi experts,
I just got to know on how to key in some information or data in a database platform and I am wondering if how to create backup mdb schedule? I need to create a back up for an mdb file for schedules. Please do share with me your experiences in this kind of matter I am using ms access database software.
Thank you.
Best Answer by Head Jonathon
Answered By 5 points N/A #180475
You can use auto saving software for creating back up files of your database. Mass Backup is automatic backup software for database. It works great for mdb program. The procedure is not so much hard to understand. Only three easy steps you have to follow.  The specific steps are prearranged in the website.
 http://www.helpconsole.com/DemandTools/default.aspx
Answered By 0 points N/A #180476
Hi Danield,
You can take a backup using the Microsoft Office access. Select Back Up Database in the file menu.
Mention the name and location of the backup copy in the Save Backup As box.
You can also run DOS commands to do the backup. There is a Scheduler on AccessWeb to take the automatic backup’s.
Also there are other tools like Total Access Agent which takes the backup.
Thanks!
