How to create boot loader for RHEL?
I have a problem with a boot loader, my Linux OS is not booting, and I lost my Linux to access.
I found the problem that when I install Windows it killed my Linux OS, anyone can help me out?
Hi Salu,
Don’t worry too much; you can get your links back within few commands
just following this instruction below.
If the boot loader corrupted:
Start with startup disk, the first command will
# Linux rescue
Then…
# chroot /mnt/sys_image
# /sbin/grub-install /dev/hda
# exit
# exit
If the problem will continue next step will…
# e2label /dev/hda0 -X
if found /boot and its number , put the before /boot
number on the # root (hd0,X) command in the grub
prompt .
# grub
# root (hd0,X)
# setup (hd0)
# quit
I hope you have your Linux back now
