How to create a bubble sheet in word 2010
Hello Friends,
I need to create a bubble sheet in Word 2010 for designing an Answer Sheet that can be used for Optical Mark Recognition or Reading (OMR Sheet). Please do the needful for guiding me on how to create a bubble sheet in word 2010.
Thanks in Advance,
Mcray Madden
Answered By 50 points N/A #168125
You can follow one of the below two solutions
Solution 1
In the tool bar Insert ->Shapes->select oval-> come to your word document and click the paper and make it resizable to your need
Then take copies and make a row of 4. (Assume one question has 4 answers)
Now insert a table with two column and format it like below.
Now you can copy first row and make number of rows you need in the answer sheet
Solution 2
There are software products like PSTricks and multido you can use these as well.
