How to create ce program a create eml?
Hi Experts,
I want to know about  ce program a create eml. I am having C software on my pc. I want to create eml on ce program. I tried C parameters like C compile but unsuccessful. I need sample coding to achieve this?Any experts please. Thanks.
Nimrod Abot
Answered By 590495 points N/A #133287
I cannot seem to find the “CE” program you are referring to in your post where you supposedly want to create the .eml file. Instead, what I found is a script that uses the wrapper C# class that can extract email fields from EML files. You can download the source code from Retrieve Email Information from .EML Files.
The source code is only around 3.28 KB and is contained in a ZIP file. The page also describes how the source code can be used. Below are the images of the codes:
