Walter Neff
30 points
Posted on - 10/06/2012
Hi. I want to design sports certificates really fast, but i do not know the best template or programs to use or download from the web. I would really like a program that has beautiful colored design templates that i can easily integrate and create my own certificates from. Kindly assist anyone conversant with certificates in design.
How to create a certificate in design?
Hello Walter,
If you have Microsoft office then you can use microsoft office publisher to create beautiful certificates.You should have some of the basic ideas of how should the background of the certificate look. the inner text and any other content o=if you want to add to your certificate.
Convert your ideas into Google image search for the background and the foreground images according to the colour scheme you have thought of.
Download the images and import it to a new publisher document.
Select the page size of your choice and paste it in your background.
I think this is the most easiest way to create the certificates and requires the least technical skills and knowledge.
