I use ms access 2010. I want to set background color of the forms with gradient color. I do not know about color gradient ms access because I am new about it. I want to know how to create gradient color on it. Please help me.
How to create color gradient ms access 2010?
please follow the guide line hopefully it's working.
1. Go to Access 2010.
2. Go Office.com Templates section, click on the Samples folder and then download the standard Northwind sample database.
3. With the Northwind database open, open up one of the forms in design view. For example, the Customer Details form.
4. Once in design view, bring up the Form Properties window. To do this, right click on the form and choose Form Properties.
5. The properties dialog should now be displayed and it should be showing the form properties. Click on the Format tab in the properties sheet. If you look at the Picture property, you will notice it is shows Image. If you delete the value for this property and then view the form, you will notice the form header really only has one background color set.
Best of luck.
