Hi Techyv members, I would like to know how to create  CSS for powershell effectively. What do I need to do first? Can you give me a technique for effectively formatting this? Please also give me the correct script for this one. Recommendations and suggestions are always appreciated. I'm looking forward for your answers.Â
How to create css for powershell effectively?
If your aim is to do some elegant style of tabular outcome from your PowerShell, and you wish that certain number principles have a different qualifications shade. I will counsel you to use this two strong programmatic techniques, namely ( outcome XML and converts it with XLT or you can use HTML and beautify with CSS) the first technique is more complex, this is because it is able of embedding the choice requirements ( the XPath) for above mentioned elegant style. However CSS needs assistance to perform the same operate. If you wish to cure a particular mobile as unique, then you will need to differentiate it from friends which have a category ID or something that drops along that range. Energy is not able of doing that natively, this implies that you will be parsing HTML as it results in turn to HTML and including.
