Morse
230 points
Posted on - 05/16/2011
I am doing some work with Excel. I am not much familiar with VB but the Excel macro seems easy and interesting. I have yet used MsgBox and buttons to do almost everything. The Excel sheet was the main window which is used as a form for hosting the other stuffs.
For example if i need 3 data to input I use something like
x = InputBox("enter the value", "Its the title")
3 times.
Now I think it would be cool to have my custom popup messages/forms for doing all these. But how do I do this? Please help.
How to create a custom Popup form in Excel
That was a pretty clean solution by Simmy.
If the toolbox doesn’t show up go to view toolbox.  And yes no matter what you add in the form, give the form (itself) a good relevant name like "datainput". You have to use to show the form.
Morse
230 points
Thanks for the sharp reply.
I have made the form as you said. The name of the form is "datainputform". The three fields are
Now what?
Giving the text field name "Name" may conflict with other attribute. Name is also a attribute . So instead of "name" give it "NameField"
When done, double click the button in the form and do your calculation there. You can access the value in the 3 fields by:
NameField.Text
ID.Text
Payment.Text
Hope this helps.
Simmy is right. And yes, when you are done with the form, you have to add this:
datainputform.Show
Wherever you want this form to be shown.
Morse
230 points
Yeppy. Â Thanks both of you.
