How to create database design vehicle?
Hello techyv,
How to create a database design vehicle? I love cars and want to make some business out of it. I need to create a website or E-commerce to let the customers view the most affordable and new designs of cars. I want some help from you on the planning of the database and the programming language to use.
Expecting some help from you guys.
Best Answer by Babb Samantha
Answered By 0 points N/A #184944
The best way is to hire a programmer give your requirements to him so that he can make a design. PHP with my SQL will be perfect for making a web application. If you think that you are having a larger database than go to asp.net and use SQL Server. I hope you will select one according to your needs.
Regards
Answered By 10 points N/A #184947
Hello Raine,
Because you are beginners, I think you should check the website. Which will provide you all types of database model for every sector. Choose the right one for you. I think that would be easy for you. You can get car data in XML format.
I am showing you a model which is a Car sales database.
Hope through this website you will learn how to make a good database. Please check the Database link.
Hope this would help you.
Thank you.
