Hi database experts,
I am fed up of creating database diagrams before working on any new project. I want any tool that can create database diagrams from the tables and information needed for flow-diagram. Can anyone suggest me how to create diagrams from the MySQL database diagram generator.
How to create diagrams using a MySQL database diagram generator.
Hello Dorothy,
Visual Paradigm for UML 9.0is awesome and I used to work with MySQL bench but for big databases it won't work very well. What I’m recommending for you is Visual Paradigm Reverse Database. This works so much better. And also I believe Database Designer does something like that. You can download the Visual Paradigm Reverse Database by using the following link.
Download Visual Paradigm Reverse Database software
Thank you.
Rubi Sharlene
