How to create DVD holding HD to be played on another X-Box?
I ran Multi-AVCHD to set a HD program, which I shot by using a Canon A1 to a normal sized DVD.
I wanted to hand over this to a friend of mine, so that, he could notice what High Def from an A1 seemed. Before that, I tested the disk on my PC as well as my Panasonic DMP-BD35. Both hold it very well. So I felt, I was all set.
Also, the Penny was able to play AVCHD. However, I couldn't recognize whether the X-Box has that ability.
I need an answer. Is there a technique by which, I can create a DVD holding HD that will be able to play on his X-Box?
Something is absent here. I have to know it. Please help me.
Best Answer by Nichols Fryman
Answered By 0 points N/A #152418
Good Day,
Upon Reading your question i should say yes there is a way to play HD DVD in your Xbox the things that you should do is first Download the Any Video Converter Software. Just looked for the Full Version.
Answered By 15 points N/A #152419
Hi Kathy,
The DVD to run the games on a XBox can be created by using the following steps:
1) To burn a game you need an ISO file from the system
2) Download the ABGX software from the ABGX Official website
3) Install the software in the system
4) In the ABGX 'options' menu, Check the 'Fix Audio padding' and 'Check any DVD style game' checkboxes
5) In the Autofix menu option, select 'Level 3' for the Autofix threshold
6) Load the .iso file into ABGX, click 'AutoFix' menu, Click 'Install'
7) Select a dual layer DVD disc. The capacity should be 8.5 GB
8) Insert the blank DVD in the system
9) Load the .dvd and .iso files. Press the 'Burn' button
10)After the successful completion of the process, you get a DVD which is compatible with different XBOX
