How to create an excel line graph maker?
Hello fellows,
How to create an excel line graph maker? I think this is the hardest part to do using a Microsoft excel application. Well I can’t say that I am an expert in excel and still needing some help from you guys. Can you teach or give me some ways or tutorials that will give me an idea on how to create excel line graph maker?
Thank you.
Best Answer by Anthony Pepito
Answered By 0 points N/A #182740
Creating graphs in excel is no more a problem Excel provides very easy solution for this.
  • You need to select the data that you want to create graph.
  • Go to insert menu from ribbon bar.
  • Click on Line graph. You will see the graph according to your data. On x-axis there will be value 1, 2,3 …. by default. You can change these values.
  • Right click on graph and click on Select data.
  • There will be dialogue box open you can change value from edit button.
Thank you hoping the answer of the question.
Answered By 5 points N/A #182741
Dear,
In Microsoft Office Excel 2007 creating graph is very simple because Excel 2007 provides many kinds of Charts. First you open the Excel and enter your data. Go to Insert menu and select the Charts Group, then you can see the various type of Charts. Click the Line Chart then you will see the Chart according to your data.
Thank You.
