How to create exif voice file?
I have an exif file combined with voice and image. I want to extract the voice and image separately from the file. How can I create the exif voice file? Is there any software (freeware) to do this process? I will really appreciate help on this exif voice file problem from experts. Thanks.
Answered By 30 points N/A #163888
Hello.
There are many softwares available that can convert or separate voice and video of the exif file.
All you have to choose is appropriate software that converts or separates your file.
After a quick research I found that TOTALVIDEO CONVERTER is the software for you.
You can convert any kind of video files to mp3 and also to any other format.
Click on the below link to download Total Video Converter.
http://download.cnet.com/Total-Video-Converter/3000-2194_4-10429299.html
Thank you.
