How to create file locker php software?
40 points
Posted on - 11/23/2012
Hi everyone,
How to create file locker PHP software?
I want to create software that will enable to encrypt and lock a specific file folder or data automatically using PHP programming language.
Is it possible?
Can you rate the percentage of possibility?
And also explain why.
