How to create Flash drag and show image
Hey, I have just installed flash software, but I'm newbie here, can please anyone let me know how to create a flash drag and show image?
Hi Amaanpreet,
Drag and show image uses a little actionscript. But first you need to share which type of flash software you installed so we can provide the actual steps. Anyways, I will provide you with a link which shows basic drag and drop actionscript. I hope this helps.
Here is the link – https://www.hugedomains.com/domain_profile.cfm?d=cgshelf&e=com
Hi there Amanpreet,
Flash and drag functionality in flash is very vital to learn because this will be the foundation of your future animation codes.
And a very good tutorial can be found from Entheos.
Here is the link for the basic drag and drop Flash Tutorial.
Here's a basic drag and drop sample, hope this helps you.
Waall Mike
