How to create a Ghost of Windows 7?
I want to install windows 7 in multiple systems, Windows 7 take much time during installation so I want to create a Ghost of it like windows XP. How can it possible?
Hi there
I will be able to help you, but I have another solution where you can install Windows 7 witching lesser time. To do it follow these steps
Step 1 – Start the windows installation normally
Step 2 – Select Custom when this window appear
Step 3 – Then complete all the other necessary formatting steps and start the formatting process.
Step 4 – Press Shift + F10 when this window appear
Step 5 – Command prompt will appear when you press Shift + F10, Type taskmgr and hit enter to open task manager
Step 6 – Select Install window and right click on it
Step 7 – Click Go to process
Step 8 – Select Set up and right click on it
Step 9 – select Set priority and select real time as the priority
Step 10 – Its done windows will be installed faster than the normal time
Best of luck
Taylor B Campus
Thank you
Hello
I think the best way in win7 is to make a system image not ghost one to make system image do the following :
1 – Click (start >Gettings Started >Backup your files).
2 – Click on (create a system image).
3 – Choose where you want to save your backup image (on hard disk, on DVD, on network location).
4 – If you choose hard disk, then select the drive you want to include in backup.
5 – Confirm your backup settings.
6 – wait till the progress done.
7 – After the progress is done you will see a question of (Do you want to create a system repair disk?)  click yes .
8 – select  DVD, and put an empty one in your DVD room, then click (create disk) .
9 – when it comes time to restore your image, use system recovery option to get your system back.
I hope these steps will help you solving your problem.
