How To Create A Google Account Without Gmail In A Few Steps
Hi. I have my Google account synced in with my previous Gmail Id. However, now I want to create a new Google account without Gmail synced into it. Can it be created? How to create a Google account without Gmail? Please reply ASAP. Thanks in advance.
Answered By 1190 points N/A #177791
Hi. To learn how to create a Google account without Gmail, first open the website of Google and click on the sign in option. To create a new Google account, click on sign up option for the form. Enter the username and enter it on the Choose your username box. However, this username will be the Gmail account which will be associated with your Google account. To disable the Gmail account, click on the option I prefer to use my current e-mail address. After this, enter the e-mail address other than the Gmail address in the username option. Type the other fields as well so that the Google account gets created without Gmail. You can also add in your birth date, select the recovery options and also add your mobile number to increase the security.
Hope we helped.
Answered By 590495 points N/A #309644
A Google account is different from your Gmail account because Gmail refers specifically to your Google email account only. A Google account refers to all other Google products and services that requires authentication including Gmail, Blogger, Google+, and Google Hangouts. It is a user account required for authentication, access, and authorization to particular online Google services.
Other Google products that don’t require a Google account include Google Search, Google Finance, YouTube, Google Maps, and Google Books. By default, when you create a Google account it will ask you to enter a Gmail account.
But if you don’t want to use your Gmail account or you simply don’t have a Gmail account, you can also create a Google account using a different email address that is not Gmail. To create a Google account without using your Gmail, go to Create Google Account without Gmail. Here, in the email address field, enter your email address that is not Gmail.
Follow the instructions to complete the sign up. When you are done, you need to verify your email address to finish creating your Google account. Log in to your email account then open the verification email message sent to you by Google. Click on the verification link to verify your Google account.
Once your account is verified, you may now selectively enable or disable different Google applications in your Google account.
