How to create group in faceBook
Facebook is a social networking. You can use it for communication, business and different work. Creating group you can do many things. You can do many things with your group. To create a group you must need a Facebook ID. Without Facebook ID you can open the fan page but not group. So, If you don't have any Facebook you create by going https://www.facebook.com/. In your profile at the left side there is an option named Create a group. Click on the option (create a group). Follow the steps carefully. After creating groups you can add your friends to that group.
This is a simple solution which you can very easily solve using the following steps;
In the main Facebook window, go to the Groups option in the left pane.
Click on it and then click on the Create Group option on the right pane.
Create the administrators in the window that opens and select also the officials and enter the name of the group. Fill in all the options in the form and click on Create group.
Your group should now be created. You can upload your picture and also customize your group.
Hope this solves your question.
