D Manob
10 points
Posted on - 08/20/2016
HTML table offers highlighting our data in a representable manner. It is a cost effective way to promote. It is very necessary to know how to deal with rows and columns. How to create an HTML table?
Oakes
How To Create An HTML Table With The Help Of Steps?
HTML table can help in highlighting our data in a representable manner. It is a cost effective way to promote. You should know how to deal with rows and columns.
Step 1: Type HTML text that you want before the table in a text-editing program such as Notepad, Wordpad, etc.
Step 2: Type <table> tag to define the use of the table and then press Enter.
Step 3: Use <tr> to open table-row and hit Enter after completing.
Step 4: Use <th> for table header opening and name the first column.
Step 5: </th> is useful for closing table header item and press Enter.
Step 6: Use </tr> for closing the row and press Enter.
Step 7: To begin another row, use <tr> and hit Enter.
Step 8: <td> is useful for entering the table-data.
Step 9: Enter the data in each field and close it with the help of </td>.
Step 10: Type the entries and close the table by </table>.
