Dear Techyv members. Hope everything is fine. I would like to know how to create html template access export successfully. What are the steps needed for this? Please include a brief overview of the process and also its key features. I'll be looking forward for your answers. Thank you so much.Â
How to create html template access export successfully?
Hi Salie,Â
Here's how to create html access, hope it could help.
1. Open text editor ,create a new file. Save empty file with an .html file extension
2.Add beginning  and last HTML tags <html> and </html>.
3.New page header between the HTML tags: <head> </head>
4.Set title using title tags and Access title token just add <title><!–AccessTemplate_Title–></title> between the head tags.
5.Add content area of the docs using the start and end body tags after end head tag: <body> </body>.
 6.Navigate reports using Access navigation tokens for the first, next, previous and last pages as  link references.
7.Just add Access  token, <!–AccessTemplate_Body–>, below the page where the content to be inserted.
8.Use Access page number token to display the current page number
9.Continue editing the HTML to add  other elements.
