How to create incremental back up vbscript?
How to create incremental back up vbscript? I am just a newbie in the world of vbscript programming language and I am confused on how to create incremental back up vbscript. But if you can give me some video tutorials on how to perform this kind of program it will be very easy for me. I hope you can help me out of this issue. Thank you
Best Answer by Alcaraz Jody
Answered By 0 points N/A #181919
You can backup your scripts in accordance with time and date. To do this you have to configure the set up with your administrating profile. Then give concentration on the steps described in the highlighted source of tutorial.
https://www.sevenforums.com/tutorials/203191-backup-make-create-incremental-backup-shortcut.html
Read cautiously all the steps along with warning messages.
You will obviously be able to create it.
Answered By 5 points N/A #181920
1.       First click on the tab of back up and definitions files then select c as an example.
2.       Click on Generate VBScript.
3.       Select the ‘VBScript files’ tab from the above menu. You should see VBScript you have created.
4.       The select VBscript you made and then right click and use edit, you will find the notepad.exe extension.
5.       Go to the link below and copy the code to Vb.
http://kb.macrium.com/KnowledgebaseArticle50146.aspx
