How to create internet forms with animated text
Hi, I want to know how to create internet forms with animated text. I’m adding a subscribe form on my blog sidebar. I googled some sites that allowed me to customize forms but the customization options were only limited through their templates. I need to find a guide on this and make my text animated on the form. I haven't done this before.
Best Answer by Bennie S Easter
Answered By 20 points N/A #155914
Hello Dee Dawson
To create animated texts into the internet forms, like registration form, subscription forms , you first have to create GIF animated pictures.
While searching I found some sites and guides which will be very helpful to you. You can take a look at this article below
https://itstillworks.com/shockwave-vs-flash-5685435.html
To create simple GIF animations really fast , you can use this online tool below
Its great and fast – textanim.com
Hope this will help resolving your problem
Thanks
Bennie
Answered By 40 points N/A #155913
Hi dear Dee dawson,
I saw your problem and now i am going to give the solution for your answer.
The following system may help you to control the problem.
Would you please read the following instructions please-
The following website helps you to create the text easily.
The main facility is its totally online based. You can use these smoothly.
There you do not have to know programming
Check here Flamingtext
