Kyle Berry
30 points
Posted on - 12/08/2012
Hello Techyv,
How to create a Joomla product comparison table?
I don’t know the proper and correct format of making a comparison table chart, I got grocery store products such as, milk, coffee and more. I would like to make some report regarding the sales and other important details such as adding a description of the product, link and other information.
Expecting some help from you guys.
How to create a joomla product comparisons table?
You can use Joomla comparison table plugin. It takes table of products from a content article. It is easy to install and use. Download the Joomla comparison table plugin. Install the comparison table plugin by following these instructions.
1. Click Extension > Extension Manager in Joomla admin panel.
2. Browse to downloaded comparison table zip file and click update & install button.
3. Click Extension – à Plugin Manager.
4. Here you will see installed plugin content – à comparison table.
5. Enable it.
6. Now create the article by clicking Article – à Article Managerà Add New Article.
7. Insert tag {comparison table} into the article where you want to display the product visibility selection. This tag will show the selection checkbox with the product name.
8. Now insert a table into the article and assign table comparison table to table id.
I. Â You can insert the table by clicking on the insert table toolbar in WYSIWYG editor.
II. If you don’t see this option then go to Extensionà Plugin Manager, you will see Editor- TinyMCE.
III. Click Editor-TinyMCE and Change the functionality to Extended under Basic Options.
9. You can insert as many columns as many products you want to display.
10. In the first table row give the name of the products in columns.
11. You can add images in the second row for each product.
12. In the third row for each product you can set the price .
13. You can add as many rows as you want.
14. Now access this article page. Select the checkboxes to compare the products.
Hope this will help you.
