Hello experts,
How to create Joomla slideshow background? Some slideshow background is needed for my website using Joomla. But I don’t have any idea on how to perform such thing. I want some tutorial that will really help me a lot to get this done immediately. Hoping for your kind consideration.
How to create joomla slideshow background?
You can use the Joomla BT Background Slideshow  extension for fulfill your task.
Below stated the link for download the extension. It's a background slide show module. Once installed you can find it in the modules tab of Joomla work space.
Then you can use it for generating slides shows as you wish.
selim99
TO CREATE JOOMLA SLIDESHOW BACK GROUND FOLLOW THIS STEP:
GO TO JED (JOOMLA EXTENSION DIRECTORY) Â PAGE{Http:extensions.joomla.org/extentension/photos a images/images slide show/page2>download free program to c drive.
GO TO EXTENSIONS > INSTALL TAB > EXTENSIONS MANAGER > INSTALL PAGE > CLICK BROWSE BUTTON > SELECT UPLOAD FILE AND INSTALL. AFTER SUCCESSFULLY INSTALLED GO TO EXTENSIONS > MODULE MANAGER > DISABLE OR MOVE ANY MODULE > THEN FIND THE S5 IMAGE AND CONTENT FOLDER > DOUBLE CLICK AND EDIT. IN THE DETAILS PAGE USE THE FOLLOWING STEP:
SO TITLE: NO
ENABLED:YES
POSITION:USER2 {IF YOU ARE USING THE MILKY WAY TEMPLATE}
THUS YOU CAN CREATE JOOMLA EXTENSION SLIDE SHOW.
THANK YOU
sharif_z
