I'm trying to create a compilation of music videos in an m2v format with a permanent logo on it. The videos are in MPEG format so I'll probably need a converter. I'm planning to use Super video converter with logo maker. What is the easiest way on how to create an m2v logo using the said converter?
How to create a m2v logo using Super video converter?
Super video converter is easy to use video tool that includes:
> Convert Video to AVI (DivX, Xvid).
> Convert Video to WMV/ASF.
> Convert Video to VCD/SVCD/DVD compliant files.
> Convert Video to MPEG-1/MPEG-2.
Using it to create m2v logo follow these instructions:
> Click Add Files to load M2V video.
> Drag slider to find the video frame.
> Click the Screen Capture button to convert the current video frame to an image file.
> Click Open the Photo Folder to find the Converted image files.
Enjoy now.
Thanking you.
Franke Mary
