I am using logmein free for such a long period and my os is windows xp (sp2). I need to create a start up macro for logmein free when logging. Please give me the necessary instructions of how to create a macro to logmein free?
How to create a Macro to LogMeIn free?
Hellow William Harrford,
I have got the problem. You are using an older version of windows. So the required utility can not be used easily .
However you can use desktop icon to create shortcut run.
It might be seen that the short cut apparently executes the initial log on, but does not issue the password required to access a particular computer. It is being desired that the LogMeIn experts can create the option of a password for definite computer.
You can create a shortcut key for run the application.For this firstly right click on the application.press the shortcut key like ctrl+l
on the shortcut key box.
Best Of Luck
Thanking you.
Shifflett Laurel
