How to create menu following scroll in my site?
I'm interested in making some changes to my site. At present my menu is fixed. Now I want the menu (side bar) to follow as I scroll down the web page. Please explain how to create menu following scroll in my site.
Best Answer by jasonf kknisely
Answered By 0 points N/A #138909
1.   You need to download Drop down Navigation Menu Wizard. It is basically a html code and you don’t need to modify the code. You can place the menu any where you like. The important thing is that your version should support the javascript. You just need to cut and paste the code to your web page and the menu will start working.
2.   Different tool kits are having this feature you just need to install the toolkit with your framework.
3.   The jquery also provide the feature of Vertical Scroll Menu.
You can use any of the three options
Regards
JK
