How to create Microsoft questionnaire maker
I want to create Microsoft questionnaire for quiz. Please suggest me some offline and online source for microsoft questionnaire maker.
Thanks!
Best Regards
Thanks!
Best Regards
Hi Nancyhernandyu,
There’s a lot of questionnaire maker software out there depending of what you need all you have to do is web surfing, just try this out:
Hi dear,
Thanks for sharing your problem with us.
I hope you have installed MS Office in your computer. IF no then kindly install it and then install templates for questionnaire from Microsoft website. And then you can make your questionnaire offline.
You can also Make questionnaire using JAVA and PHP Scripts.
If you want to make questionnaire online so kindly use this URL to the access of that website.
https://www.smartsurvey.co.uk/online-questionnaire/
I hope this answer will satisfy you.
Regards….
