How to create a mp3 cd in Toshiba?
Hello experts,
How to create an mp3 CD in Toshiba?
I want to merge all my mp3 files at least 400 songs on one CD and how will I do that in my Toshiba desktop computer.
I hope there is a safe and fast way to do this so that it will not affect any files on my computer in case of any error or corrupted files will occur.
Thank you.
Answered By 0 points N/A #179649
If you want to write data on CD from your PC you need to use CD burner. Your PC should have a CD – writer. Simple CD or DVD Rom is not able to burn CD.
If you will use good CD burner then you will not have issues like file corrupt or file missing. The most popular CD burners are ISO, BURN my Cd etc. I am posting some links from where you can download them
https://free-iso-burner.en.softonic.com/?
https://en.softonic.com/s/nero/windows-7
Download them and use them.
Also for win7 user you need to copy data to your CD ROM drive and click on burn Disk option.
This will also burn CDs but using software is a good option
Thank you
