geodelyn
Posted on - 09/09/2011
Hello Everyone out there. I am planning to make a big banner using MS Publisher but I don’t  really know the basics of it. I just want to know how to make multiple pages per sheet. Its just like after printing, you will attached all the pages in order to make a one big banner. Any helpful tips is highly appreciated.
How to create multiple pages per sheet in MS Publisher?
I don’t know which version of Microsoft office you are using. But I will describe it with Microsoft office 2007. It is similar like other version and easy to operate. You can do it easily from the multiple pages per sheetoption. This option is in the Custom Page Size dialog box top of your menu bar. It is released by Microsoft publisher 2007.
You always use the multiple copies per sheetprinting option. You will find it in the Print Setup dialog box in Microsoft Office Publisher 2007. You can use it for change your page as you want.
Hi
the solution of your problem is simple. I by myself using Microsoft office 2003. You can do it by clicking on page option in main menu then click on custom page size , and then multiple page per sheet option check that option you will have multiple page on single sheet. Microsoft corporation also recommends this solution you can check this on Microsoft official web site. thanks
