How to create a new document using a template from Microsoft SharePoint2010?
Hi experts,
I am trying to create a new document using a template from Microsoft SharePoint 2010, but I keep getting an error message that says
Word experienced an error trying to open the file.
Sometimes, I get an error message saying "Word has encountered a problem".
Recently, when I open my documents, it says "Opening in a Protected view."
Are these problems connected to each other? How can I fix this error?
Microsoft Word
Try these suggestions.
*Check the file permissions for the document or drive.
*Make sure there is sufficient free memory and disk space.
*Open the file with the Text Recovery converter.
(http://…/Outlook Forms used in the …)
Best Answer by Nixon Cruzu
Answered By 5 points N/A #136919
A reason why you are receiving the error message is that you are running it under a protected mode here are the steps to follow in resolving the issue:
You must add the Office 365 or Share Point site as a Trusted Site in Internet Explorer. Follow the steps below:
  • Launch Internet Explorer.
  • From the menu select the Tools option.
  • Select Internet Options.
  • After selecting internet options choose Security tab.
  • And then you have to click Sites, and click the Trusted Sites green tick.
  • You have to type your domain into the text box and click Add (Open the attached file to view the image).
  • And then click OK.
Answered By 90 points N/A #136920
I have been experiencing the same problems. Now I know what to do.
Thank you dear Nixon Cruzu and ever so helpful techyv.com.
