Hello experts,
How to create or edit ios crop faces? My iphone with an i operating system has many photos of mine with friends and I want to crop some important photos for my facebook profile picture account. What is the best built in editing software in iphone? Thank you.
Hi Kristen, you can crop the images by hitting the menu button, click on “Photos” then select the “album” where you saved the photo that you wanted to crop. Now, select the specific image by tapping it, and click “edit” then select “Crop”, it will then show you grids on the image. Drag the corners/edges of the grid according to your preference. Hit “Constrain” so you can set the image size. Tap “Crop” and hit “Save” . Also check this link for the top 5 iphone photography apps: http://www.oxis-immo.com/en/
