How to create oracle apps r12 tables?
Hi fellows,
I am just a newbie about this kind of technical database stuff.
Give me some tips on how to arrange and give values for each table.
Thank you.
Hi fellows,
Thank you.
First of all i would like to say that giving the first approach to Learning Database using Oracle is not a good idea. Learn a more easy and good software like My-sql. If you are able to master that you can manage any other kind of Database software.
https://www.w3schools.com/sql/default.asp Visit this site and learn My-Sql it gives the Basic steps for everything starting from the very beginning
After searching for the solution of your question about creating Oracle application R12 I have found lots of solution. I think the link given  below will help you to get your perfect solution step by step. There are 10 steps for you to create the application. Here is the link https://www.w3schools.com/sql/default.asp
