How To Create Org Chart In Powerpoint In Just Some Simple Steps
Hi. I am a novice related to computers. I have recently started using PowerPoint. We are required to prepare and submit an organization chart in the office. How to create org chart in PowerPoint? Please reply ASAP. Thanks in advance.
Answered By 10 points N/A #113325
Hi. To learn how to create org chart in PowerPoint, first click on insert menu and from the illustrations submenu, click on SmartArt. Click on the hierarchy option from the Choose a SmartArt graphic gallery and then click on OK. Next, type the text in the SmartArt graphic. You can either type the text in the box or copy text from another location as well. To add boxes in the organization chart, click on the SmartArt graphic where the box is to be inserted by clicking on the existing nearest located box to the new one. Then, under SmartArt tools, click on the design menu and then in the Create graphic group, click on add shape. Then, click on the Add shape below/above/after option. The box can be deleted as well by clicking on the border of the box which is to be deleted and then selecting the delete option.
Hope we helped.
