Mili Nelson
Posted on - 04/04/2013
Hello expert, I am studying about networking systems. So I have to know about how to build own gps system. Actually I am using windows 8 OS and I want to build own gps system using software or non software. Please give me some information to do it properly and provide me some links to download. Thanks.
How to create own gps system using software
Hello Mili,
It looks like you want to create your own GPS and you are looking for a software for that. Having your own web-based mobile GPS tracking system is not so complicated or expensive either. You can build your own simple mobile GPS tracking system from a laptop and the data will be delivered via Internet, to your own computer. With the addition of a web server, and Google Maps, you'll be able to see the data over the web through an interactive map. Here is the link which has a guideline on creating GPS system.
http://www.opendmtp.org/article/webserv/
You can also build a GPS receiver on a FPGA board and it can be connected to your pc for receiving GPS signal. The link is as follows http://www.extremetech.com/extreme/98063-how-to-build-your-own-gps-receiver
I hope this helps.
