How to create partition without reformatting Windows 7?
Hi all,
I just changed my old hard drive that I let go for a new 250 GB, but will have one single volume I want to divide it into two, without losing my data . Tell me one software or technique to partition without formatting or deletion of data. I am on Windows 7 professional 32 bit.
Best Answer by kawaiiaerith
Answered By 0 points N/A #130891
The easiest way to make partitions with a new hard disk or with a hard disk where you can erase all data is when you make the installation of your OS.
During the installation process you get the option to select the drive for the installation that is exactly where you can change the size of the partition that will be used for the OS and also create other partitions.
So next time when you do a clean install with your hard disk, try that method. It will definitely save you time and resources.
Since you already have your OS installed and would like to preserve the data already in your HDD you need a third party software.
My recommendation goes to “Easeus Partition Master Home Edition” which is absolutely free to use for home users.
You can look at more information or download the software Easeus Partition Master Home Edition
Good Luck
Answered By 0 points N/A #130892
To partition your new hard disk into different storage and without formatting, try to follow these steps:
  1. Start your computer and go to "Command Prompt" Mode.
  2. On the command prompt, type "FDISK".
  3. Press 1.
  4. Press 2.
  5. Enter N.
  6. Indicate the disk space you want to be allocated to the created partition.
  7. Type in the name of the newly created partition and press "Enter".
  8. If you want to create more than 1 partition, then repeat steps 5 to 8.
  9. Exit the command prompt by pressing "Esc".
