How to create a photos slide show? I am using movie maker software and having a hard time to locate all the pictures to present them as a slideshow. Share with me some of the features of the movie maker that will allow me to perform a photo slide show. Tell me more about movie maker styles and slide show techniques.
Thank you.
Hi Ericson Eric,
I have seen a lot of sites that is giving some tutorials and step-by-step procedure in making a slideshow using movie maker. Kindly check the links below for more information.
Hope that it would help you a lot.
Please follow these to make your photo gallery:
GO to files
Import your photos in to collections.
Under dropdown menu you need to select picture files.
Use Ctrl key to add more photos and press import.
Once all pictures are in collection folder.
Now put photos to time line as you require showing them.
You can also add slideshow effects to make slide show more effective.
Now play the sequence of frames you created and you will be able to see the result.
Smith Thompson.
https://www.tripadvisor.com/ is a website which gives us the chances to make different type of slide shows from our pictures.
You may have to create an account on this site and now you can easily make slide show from your pictures and then you can download it on your pc for subsequent use like upload on YouTube or Facebook.
Hello Ericson Eric,
If your having a hard time putting all the pictures one by one, You can use the shortcut command Ctrl+A and drag the pictures to the Storyboard or timeline.
Hope this helped you.
Hello Eric,
To make it simple try to put your photos first in the desktop so you can see it directly when you will use the ctrl+o open. After putting it in the desktop try to put it to the storyboard inside the storyboard you can animate or change its graphics the way you like. In the storyboard you can make some adjustments in your timeline. After editing and making all of them now you can save it our import it.
