How to create a php pop out form? Html connected to php programming language is not an easy task to do; it needs focus and dedication to get the work done. I would like to ask you if you are familiar with the codes for php pop out form, give me some ways to learn this and guide me along the process as well. Thank you.
Hi Anthony Wendy,
There are lots of possible solutions with your problem. There is a lot of codes that is out in different sites. I think that the best solution is to join the discussion of different sites to gather ideas and information in making pop-up form in PHP. I have attached some links of possible sites that maybe useful as your reference.
Danieb: PHP Form Pop up- window possible?
Stackoverflow: Pop Up PHP Form
kdta91
Hi Anthony!
Creating a popup form on plain PHP is not a good idea. Why? Because when you submit the form, the whole page will reload. Therefore, if there are any errors in the input, all the correct data that was inputted will be lost and you will have to input it again, which is somehow time consuming and frustrating.
What I recommend is to use Ajax when making any popup form because whenever you submit the form with incorrect input, the page will never reload which means that all data input will be retained on the input fields.
I hope it helps!
