Hello techyv!
Is it possible to create a portable ipsec vpn client? I have searched google but unfortunately did not find tutorials on creating portable ipsec vpn client. If this is possible can you show me how to do this?
How to create portable ipsec vpn client
Hi Lutter Mandrane,
This IP Security Virtual Private Network is possible to create a client, I am using Hamachi VPN software in order to connect to my cousin who is far away from my home. We do mine craft game there using Hamachi VPN and it works fine for us, I would also glad to recommend this software to you for it is a good VPN software that can satisfy your need.
Hi Lutter. I would highly recommend you to use hotspot shield. It is the world’s most popular Virtual Private Network (VPN) that secures your browsing session, detects and blocks malicious websites, makes you private and anonymous online, and allows you to access any blocked content. It allows you to secure your web session, online shopping, data and personal information online with HTTPS encryption. Hope this helps.
