How to create a program compare character line?
Hello experts,
The programming languages that I know is C++, java and PHP programming language.
I hope you can give me a suggestion on what programming language will I choose to create a program compare character line?
And some downloadable sample codes will help a lot.
Thank you.
Answered By 5 points N/A #175216
Hello Deborah Hall,
Here you will get the sample code of program compare character line.
Sample is given below:
#include<stdio.h>
#include<string.h>
int main()
    FILE *ptr_file;
    char buf[200];
    char key[] = "test";
    int wordcount = 0;
    ptr_file = fopen("input.txt","r");
    while (fgets(buf,200, ptr_file)!=NULL)
        if((strstr(buf,key)) !=NULL){
            wordcount++;
    fclose(ptr_file);
    printf("%d",wordcount);
The above code will help you to compare character line.
