How to create roller in Silverlight?
I want to create a complicated “roller” in Silverlight. I plan to have this “roller” that can show me the percentage on how long a user should wait.
It can already determine the percentage of what’s going on.
I just want to add another feature of my “roller” in Silverlight.
Answered By 0 points N/A #105958
It is very simple to control this kind of roller blind that is free. To be able to use the Roller blind control you will have to add a reference to your project's liquid dll. You have to log in to and registration is free on the site https://www.vectorlight.net/silverlight/controls. Ensure you have no bugs fix all that are present at the site to enable you change or work properly on this site.
The other option is for you to check the Kothari's Silverlight FX project. It will enlighten you on how best to go about creating this kind of controls. I hope this will be of much help to you.
