How to create an RPG Service Program?
I would like to develop a RPG Service Program that will be place in the memory and will work when a user press the function key while another program with DSPF is interacting with the user. Can you help?
Hello
As RPG service program developing is that save whole data and file in the Memory Card. When you are the available user of RPG then it will very easy for you. If don't then follow me.
At first create account over the system then sync through your system. This option gone happen to your file saving. It works like back up services.
Press the continuing button for sharing your saving program. There other users can interact on your system. There upgrade processor you need to keep running with DSPF. So some complexity of your PC will have faced if you don't upgrade one.
You can solve by your choice. Thanks
Notifications
