I just want to ask if how to create salary statement in excel? I am asks to do some report for this and I am not an expert when it comes to Microsoft excel. Can I download some samples in the internet? I need your help guys.
Creating Salary Statement in Excel is very helpful for counting the expense. Microsoft Excel makes is easy for the accountants. To create a Salary Statement in Excel you have to follow the instruction. Those instructions will get below link:
It is very easy to make an expense sheet in excel.
If you have not much knowledge about excel so i am going to tell you the method to create expense sheet in excel.
Select your desired cells vertically Means, suppose you have to add only two columns is this sheet column "A" for expenses and Column "B" for amount.
So,
    A                                                  B
Here type all your expenses                     Here type amounts of expenses
    a                                                 25
    b                                                 35
    c                                                 45
     d                                                 1560
     e                                                 65
     f                                                  7859
     g                                                  369825
Total                                              here put formula of sum to count all amounts only.
                                                  =sum(cell address1:cell address last) then press enter.
This is a simple expense sheet.
If you want to download expense sheets kindly check this url.
1....
