jabez zion
10 points
Posted on - 01/25/2013
Hello Experts,I am trying to create uml diagram for insurance, based on use case diagrams model theory.As you know scenario is revoked when someone interacts with system.I am looking for all header elements of a scenario applicable for a insurance company.Can you guide me in completing this diagram.Thanks.
How to create scenario in uml diagram for insurance?
Hi Jabes,
You want to make your UML diagram so you should get a first Visio application because it is mandatory when you write any UML diagram so symbol should be correct if symbol is not correct so you all diagram has no worth. And when you write any test case so make diagram with the help of test case. Hopefully this information will help you.
Thanks,
Raun Nelson
