How to create script in db2?
Can anyone tell me how to create scripts in DB2 to make DB2 Database?Â
Are there any certain requirements to make DB2 database?
Thank you very much.
Andrew Patersson
Andrew Patersson
On the link below you will find how to create a DB2 Database with Script. Prerequisites that you should have are configured IBM DB2 database user and group, added the database and the client instance registry variables.
Procedure for creating DB2 Database you can see on this link:Â
About prerequisites you can find out how to configure at the left side on the website, in the table Contents. Also you can see how to create DB2 Database Scheme, how to configure a connection to local DB2 Database and Remote DB2 Database.
Williamson Mellisa
