How to create a shared calendar in Outlook in different ways?
With the help of calendar we can share business dates and appointments. We can also share this with the group. How to create a shared calendar in Outlook?
With the help of group calendar we can share business dates and appointments. We can also share this with the group.
Method 1-
Step 1- Make a folder to which your group people can have access to.
Step 2- Select Go Menu and then Calendar after opening Microsoft outlook.
Step 3- Select Actions Menu and then View Group Schedules then Add.
Step 4- Enter a group name and then press OK. You can also click Add Others to add other people.
Step 5- Save it.
Method 2-
Step 1: Open Microsoft Outlook then Go Menu then Calendar.
Step 2: Select My Calendars and then the link "Share My Calendar."
Step 3: Allow or don't allow Request permission to view recipient's calendar.
Step 4: You can add text and create the new one using My Calendars.
