I am using Share point Version 2007 and Lotus Notes Version 7. I am looking for help to create share point for displaying Lotus data. How can do this? Is there any application to do this? Is there any tool to do this? Or any training is available to do this? Can I use the XML for this? I have only very limited knowledge in Lotus.
How to create SharePoint for displaying lotus data
Step By Step instruction in this article: (please read it I think you can get a help for your problem).
Lotus Group
Quest Notes Migrator for SharePoint migrates:
Lotus Notes, QuickPlace/Quickr and Domino.Doc applications to SharePoint 2007/2010 and SharePoint Online/Office 365 with high fidelity and fewer development resources than you thought possible.
Queest
Hey Azalea!
You can have a look at the step by step guide of creating a SharePoint list here in this URL. This is a image embedded walkthrough, and so I assume you should not have any problem following. If you do encounter some problem, or you're stuck, feel free to contact. Visit this link.
This is done using XML only.
Hope this helped you.
Cheers!
