How to create a simple sea texture website background?
Good day to all.
My professor gives me a project and he wants a sea texture website background.
Can anyone help me to create the website.
Or can anyone give a tip or advice to have a nice but simple sea texture website background.
Thank You.
Best Answer by Joseph H Higuchi
Answered By 70 points N/A #172969
Hello, Fernando.
Well, I would like to know more about this project and how much do you know about websites and design so I could help you more. But, lets answer on your main question.
Speaking of sea textures the easiest way is to create it in Photoshop. For example, take some free sea image from the Internet, open it with Photoshop and play with effects such as texture effects (maybe the best).
Go to Filter tab and try different effects to see what will fit you the most.
By opening each effect you will see the box in the preview of your image on the left side if you apply the chosen effect and on the right side there are properties where you can change the intensity, thickness, light, relief, contrast and other similar characteristics by simply moving your mouse left and right (depends how much changes you would like to do).
If you want inspiration on the following link you can sea lots of sea photos and textures http://all-free-download.com/free-photos/sea-texture-background.html.
If you have more questions you can ask us.
We will be glad to help you.
Answered By 80 points N/A #172970
Greetings Fernando W Alvarez,
Your best solution is to Google some sea texture images. Creating one probably requires a Photoshop expert. Even then it's probably hard to create it manually. But you can try.
Unless you can take pictures of your own just check out this link SEA TEXTURE IMAGES As you can see they are many you can choose from.
Try using a different search term like sea waves, sea ripples or just sea.
I hope this helps you,
Regards.
