How to create some flash slot machine design? I am using adobe flash cs5 software to create some animated slot machine design, how I wish you can provide me some coding information to get this done immediately. I have to submit it next week, tell me about online tutorials.
I suggest that you design the Slot Machine in Adobe Illustrator because Illustrator works very well with Adobe Flash by converting it to Symbol which has flash integration and then import the Native(. AI or .EPS) for Adobe Flash.
Watch this video to learn this technique.
I found this video from YouTube that can help you solve your problem. All of these guys created the Slot Machine project from Flash. I suggest that you contact these great people and ask for their help.
If you really want to become a good use of Adobe flash. Here is the link that directs you to loads of tutorial about Adobe Flash. They're quality tutorials so you may need to spend a little.
1....
